Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-29-2004, 08:37 AM
snookgirl snookgirl is offline
temp. gage ????
I have a 96 GMC JIMMY-the temp.gage goes from 220 to 260 as soon as I put the car in drive and stays on HOT,but the car itself does not feel hot.What do you think the problem could be????Just had a new radiator,thermosat,belt,pulley,fuel pump,fan shroud put in recently.Just don't know what else to do-please HELP!!!!
Old 12-29-2004, 09:30 AM
KrabbyJimmy KrabbyJimmy is offline
Re: temp. gage ????
Did you check the coolant and look under the Jimmy for any leaks? Check oil level as well.
Old 12-29-2004, 12:52 PM
Re: temp. gage ????
Coolant seems fine-no leaks either.What do you think????
Old 12-29-2004, 02:02 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: temp. gage ????
how fast does the guage go from 220 to 260?
I'd say the thermostat is sticking, but putting it into Drive would have no effect on it
Does the fan seem to be turning alright?
Old 12-29-2004, 02:49 PM
Re: temp. gage ????
Fan is fine.The gauge goes up as soon as I back out of my driveway and stays on.Once in awhile it will go back down to 220 and the CHECK GAUGE light goes off but not for long.If the thermosat is sticking how do I fix it???
Old 12-29-2004, 04:57 PM
Re: temp. gage ????
If it was the thermostat sticking, you would simply have to buy a new thermostat and put it in.
In the front of the engine, you will see where the upper radiator hose goes into the engine. That piece bolted onto the engine (where the hose goes into) is the water pump. Take that pump off and the thermostat should be right there. It sits in the passage-way that the water goes through.
Let me know if that doesn't make any sense and I will try and explain it again.
Old 12-29-2004, 05:46 PM
Re: temp. gage ????
Thanks alot-I'm one of those ladies that does not know much about cars???
