What Is Wrong!!??! Help.......
My Crx runs fine but when I stop at a stop sign it usually dies out. Is it cold weather or whats the problem???
Where does it Idle at? It could be that the throttle cabe is not set right for when it is at warm or cold idle.
It idles real low is this due to the cold weather, if it is the throttle cable how do i fix it?? Do i just need someone to reset the idle for the colder weather??
naaa you should not have to take it to get it set right. where does it idle at rpm wise. open your hood and look at where the cable goes into the intake manifold and there will be some adjusters. well not on the manifold itself but on the cable its self. if you adjust it it will change the idle.
will the adjusters just look like little knobs ??
no..it is basically a plate with 2 nuts on the cable. If you look you will know what I am talking about. you throttle cable is threaded so you will know when you find it.
