Old 12-28-2004, 11:59 PM
David Pledger David Pledger is offline
How can I test/bypass my NSS switch
How can I bypass my NSS switch to see if it is hte problem that I am having, it seems that it is goin out. My reverse lights do not work and many times my Jeep will not start, nothing, no turn over.
thanks
Old 12-29-2004, 02:39 AM
89ltd 89ltd is offline
Re: How can I test/bypass my NSS switch
is it a jeep?
Old 12-29-2004, 09:05 AM
Bypassing/testing the NSS
yes it is a Jeep it's a 98 Cherokee sport.
thanks
Old 12-30-2004, 01:54 AM
download the nss file from this link, should help you out,
http://www.lunghd.com/Downloads_and_Links/Downloads.htm
Old 12-30-2004, 07:30 AM
BUCKYXJ BUCKYXJ is offline
go to jeepin.com there is a great write up on the NSS cleaning there. Its very simple to do. also to test it when it wont start put it in neutral and see if it starts there.
Old 01-03-2005, 09:55 PM
It's fixed
thanks for the NSS switch articles. I took it apart and one of the contacts was stuck in the down position. Cleaned it all up and put it back on. Starting without any problems and my backup lights work again.
Once again mnay thannks
Old 01-04-2005, 01:07 AM
David, was it a big job, my reverse lights don't work and I know I have to do the same, I have 89 4.0 auto, trans, will fluid be leaking out as well?
Old 01-04-2005, 05:24 PM
It was not difficult, except for the part of removing and reinstalling the NSS switch. You think it's never going to come off but keep moving and pulling on it and it will give eventually. No trainy fluid comes out, it's a clean job.
Old 01-05-2005, 03:53 PM
Ironic Ironic is offline
Hardest part of the job is getting the switch off- before prying at it- spread the threaded shaft a little with a very small screwdriver (the part the nut threads to is cut into four) then thread the retaining nut on a few threads and pry under that to the tranny pan lip.
