Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 12-28-2004, 09:50 PM
dystormy dystormy is offline
Question oil leaking out the dip stick
i have a 1980 cj7 6cyl. there is oil leaking out of the dip stick. i have already replaced the pcv valve and checked for a stoped up pipe on the pcv valve but it is still leaking out the dip stick. anyone have a clue what it might be? i don't really know what to do. thanks in advance
stormy
Old 12-30-2004, 09:27 AM
stangfreak7 stangfreak7 is offline
Send a message via AIM to stangfreak7
did you over fill the six cylinder? how many quarts of oil does it take???
I know mine only takes five quarts.
Old 12-30-2004, 05:12 PM
no it is the right amount. it is like it is getting too much pressure in the oil pan and forcing all the oil out. it will keep comming out the dip stick untill the pan is empty.
Old 01-14-2005, 02:57 PM
dreymeek dreymeek is offline
Re: oil leaking out the dip stick
Pull your valve cover and make sure the passages aren't plugged on it. Can you feel vacuum on your pcv valve? If not, and the valve and hose are clear, you have a plugged intake manifold port. How about the vent hose that goes to the air cleaner, is it clear?
Old 08-07-2005, 10:26 PM
LearysGhost420 LearysGhost420 is offline
Send a message via AIM to LearysGhost420 Send a message via Yahoo to LearysGhost420
Re: Re: oil leaking out the dip stick
What you could be getting is blow-back. You might have a cracked piston.
