Old 12-28-2004, 10:30 PM
WILL_ma WILL_ma is offline
Unhappy HELP! Glue solvent
hey guys
need sum help here. i got sum glue on the windscreen of my model. do any of you know any solvent dat'd get it off? i used the Revell Contacta Professional modelling glue. i've tried using detergent and alcohol, does nuthin. I called my local hobbie shop the guy said theres no way to get it off. i'm in real shit with this one. any suggestions would be real appreciated. thnx
Old 12-28-2004, 10:36 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: HELP! Glue solvent
There isnt anyway to get it off. Except sand it off and repolish it, and maybe it will turn out halfway decent.
-Mike
Old 12-28-2004, 11:22 PM
Jaymes's Avatar
Jaymes Jaymes is offline
if it's not too bad, then sand it off with a low grit (around 800) wet or dry and then smoothen out the scratches with 1500 or 2000 grit wet or dry. Then polish it out with rubbing compound, and then dip it in a container of Future Floor Polish. Give it several coats of Future if you want. It should come out quite close to perfect
