Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 12-28-2004, 08:42 PM
hogchaser hogchaser is offline
Angry poor fuel mileage..fuel filter location
93 all wheel drive grand voyager(155,000 miles)3.3 motor...runs and starts great..14mph...no good...new fuel pump...plugs...wires..whats next????location of fuel filter?????heater kools down at a red light..heats up while driving?????Thanks all....Tim....
Old 12-28-2004, 08:43 PM
Re: poor fuel mileage..fuel filter location
poor fuel mileage..fuel filter location (Post #1)
Old 12-29-2004, 08:42 PM
Autopro Autopro is offline
Loction of fuel filter????? The fuel filter should be located under the vehicle. Put it on a lift or stand in the middle of the vehicle at the passenger side. Look under the vehicle and you will see a round canister along side the chassis with hoses leading in and out.
hope this helps
Old 01-01-2005, 03:42 PM
MR P BODY MR P BODY is offline
Re: Re: poor fuel mileage..fuel filter location
You have 2 things going on here, the heat issue is more than likely just
low on coolant, refill it, the mileage issue is more than likely your O2
sensor or your coolant switch, fill the coolant first then check it out
