Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 12-28-2004, 08:05 PM
jester69 jester69 is offline
97 Expedition wont shift out of parkwhen running
My 1997 Ford Expedition will not shift from Park to any gear when the truck is running. You can turn the key to start and then put it into a selected gear and crank the engine and it will move that way, but I dont think that is very good for the tranny. My wife has the truck in Az so I cannot put hands on to determine for myself. I am wondering why, there was nothing wrong with it before and this is something completely new. Any ideas? We were thinking it has to do with the brakes and rotors not triggering the sensor to unlock the shifter but that seems to easy.
Old 12-29-2004, 06:13 PM
ncinirator's Avatar
ncinirator ncinirator is offline
Send a message via AIM to ncinirator
Prepair to be raped by the dealership on that one.
94 Caprice 9C1, 84 CUCV Blazer, 07 TL, 96 F250 PSD.
Old 01-12-2005, 07:10 PM
pennypicher pennypicher is offline
Send a message via Yahoo to pennypicher
Re: 97 Expedition wont shift out of parkwhen running
Ya but stepping on the brake sends a signal to let it shift doesn't it? I can't shift mine till I step on the brake.
Old 01-12-2005, 07:14 PM
Re: Re: 97 Expedition wont shift out of parkwhen running
Stepping on the brake does nothing, that is why we are thinking that its that sensor gone bad...... just trying to get some feeback so we can trouble shoot better and not take it to the dealer for something minor i can do myself
Old 10-26-2005, 08:51 PM
mebush mebush is offline
check the wires going to the brake switch right at the pedal--it is coomaon for a wire to breakthere.
Old 12-09-2006, 04:04 PM
riproaringca's Avatar
riproaringca riproaringca is offline
I realize it's been a while since you posted this message, but I had a similar problem with my '97 Sable GS wagon this past spring.
Turns out that there is a 'ponytail' of wires that go through the firewall from the cabin to the engine compartment. On the Sable it's on the driver's side, on a Grand Marquis it's on the passenger side. Where all of these wires are they can chafe by rubbing against each other and sometimes the insulation covering a wire will split. In my case, there was a wire that had a split the length of a grain of rice. Over time moisture rotted the wire just like a bad tooth. Tiny little hole, but it caused the problems you're describing. And at first it was intermittent.
Through Automotive Forums I first learned about the 'BOO' Switch (Brake On/Off Switch), which is located under the brake pedal in most cases. It usually causes this problem of not being able to shift from 'Park'. I replaced that, but the problem persisted. It was my CAA/AAA Approved mechanic that knew enough about the ponytail of wires to look there, or in the area of the firewall.
I've just bought a '97 Expedition XLT 5.4 Triton w/ 244,000km from my boss. It's in great shape and I'm looking forward to using it as a second vehicle. With the help of this forum I'm sure I'll be able to keep-up with any challenges as the years add up!
[email protected]
Peterborough, Ontario
1995 Escort LX 3DR - 1.9L, 4cyl. w/ OD
1997 Sable GS Wagon - 3.0L, 6cyl. w/OD
1997 Expedition XLT - 5.4L, 8cyl. 4x4 w/OD
1999 Escort ZX2 Coupe - 2.0L 4cyl. w/OD
1999 Taurus SHO - 3.4L 8cyl. w/OD
2002 F150 4x2 SuperCab XLT - 4.6L 8cyl w/OD
