Old 12-28-2004, 07:34 PM
lucentinjection's Avatar
lucentinjection lucentinjection is offline
Send a message via AIM to lucentinjection Send a message via MSN to lucentinjection
Hf-->Dx...probs
I'm in the process of doing an HF to DX swap in my '91 CR-X, let me tell you it is one problem after another...it runs and idles, but it runs like the ignition timing is all off, and i have it all the way advanced (i think), anyone have any ideas what might be the problem here? i'm using my HF intake manifold and i have an Si computer, does the exact same thing when i install my HF computer...also exhaust is running off the B-pipe (4-2-1 header/pipe)
Old 12-28-2004, 07:35 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Hf-->Dx...probs
what dizzy are you using?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 12-28-2004, 07:36 PM
Re: Hf-->Dx...probs
if dizzy means distributor, im using the HF one...im almost positive that the HF and DX dists are the same, could be wrong tho
Old 12-28-2004, 08:08 PM
amy@af's Avatar
Re: Re: Hf-->Dx...probs
nope. hx & si = MPFI. dx = DPFI
did you do the wiring for the MPFI? you need to relocate c1 & c2 to b10 & b12 at the ecu plug. and run 2 wires from dizzy to c1 & c2. if you already did all that and it's not running right, you might have c1 & c2 backwards.
Old 12-28-2004, 08:52 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
^ that always confuses me when i read it hehehe
from what i gather he has an hf and is installing a d15b2 (dx motor) into his car. so he wont hafta do the mpfi swap. it might be a timing belt issue that he's having. fouled plug, bad wire, bad injector, something, give us more symptoms to go by
Old 12-28-2004, 10:13 PM
Re: Hf-->Dx...probs
alright...it runs and idles fine, but when i put load on the motor (acceleration) it bogs and sputters and runs like shit...it revs fine if its not being driven, meaning if i rev it standing still it goes fine...everything points to ignition timing, and i think i need the DX distributor...but i could be wrong...im using the stock HF wiring harness and intake manifold, Si throttle body...plugs and wires are good, no check engine light....so im pretty confused
Old 12-28-2004, 10:16 PM
Re: Hf-->Dx...probs
timimg belt is good too (that i know of) but if its off a tooth or 2 could that be causing the problem?
amy@af's Avatar
do you have a hf or a si?
you need to keep the same dizzy with the same ecu. if you have a si ecu and using a dx dizzy or vice versa, that is your problem
Old 12-28-2004, 10:17 PM
amy@af's Avatar
Re: Re: Re: Hf-->Dx...probs
http://www.binghamtonlife.com/manual/manual.htm
Old 12-28-2004, 10:21 PM
Re: Hf-->Dx...probs
the thing is, when i hook up my HF ecu it does the same thing.....same ecu as the dist....
Old 12-29-2004, 04:11 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
check the timing as lady posted
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-01-2005, 10:48 PM
Re: Hf-->Dx...probs
ya u guys were right...timing was off 2 teeth at the crank..now its idling weird i think my EACV is messed up, revving up and bogging down
Old 01-02-2005, 02:28 AM
]{iwi's Avatar
]{iwi ]{iwi is offline
Registered User
Send a message via MSN to ]{iwi
Re: Hf-->Dx...probs
that may be a vaccum leak
Old 01-03-2005, 12:41 PM
amy@af's Avatar
idle speed out of adjustment?
