Old 12-28-2004, 05:03 PM
ddominey ddominey is offline
Possible wind noise?
anybody out there with a 04 silverado with wierd noises? mine has a few. I was just wondering of anyone has noticed a noise when highway driving. when I hit about 115kmh it sounds like there is wind coming in the front windshield passsenger side. anyone have the same problem or does anyone know what this could be?
Old 12-28-2004, 10:08 PM
LT-Z71drvr LT-Z71drvr is offline
This may sound stupid, and I could be wrong, but it is worth a try.
I had the same problem on my Silverado, and it turned out I didnt have the passenger side doors shut tight. Mine only had three doors, and the third door wasnt shut tight, which also ment the front door wasnt either.
It sounded just as you described, like wind coming through around the windshield.
Give it a shot.
1996 K2500 Reg Cab Long Box
5.7 Vortec, HD 5-speed manual (NV4500)
LT265/75R16E Toyo Open Country M/T
Hypertech Power Programming (AWESOME)
K&N Air Filter, Flowmaster Exhaust
Centerforce Dual Friction Clutch
Pioneer Head Unit, MTX 200 Watt Amp, MTX 10" Thunder 4500 sub
"To be old and wise you must first be young and stupid"
Old 12-29-2004, 07:22 AM
exlonghair exlonghair is offline
This happened to me after installing a bug shield on my 2004......the difference in the airflow over the truck caused the side windshield moldings to "flap" at 60mph and above. You can isolate the problem with a roll of electrical tape and then do a permanent fix with some double sided tape or silicone.
Old 12-29-2004, 09:24 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Re: Possible wind noise?
I get a whistel noise, but i think its from my rain guards. and it only does at when im goin slow, like 20-30 mph.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 12-29-2004, 10:38 AM
huustar huustar is offline
I have a '99 that has the exact same problem and it is the third door not closing properly. I could never figure it out until I finally checked the door and found it was not closed tightly. I have found the 3rd door to be a real problem for not shutting tight unless it is slammed shut. I happened to bring it in to the dealer today for that and they want $220 to install a new latch system, which I think is ridiculous. As far as I'm concerned, GM should replace it for free if it is a defective design.
Old 12-29-2004, 01:06 PM
dreamer56 dreamer56 is offline
2004 Siverado Regular cab 1500 2WD. I also had installed bug shield and had immediate noise. It is the moulding around the windsheild. GM has a service bullitian out. Unsure of number. The company that installed the sheild states his local dealer is sending all to a local glass shop for a fix.
I have not had mine fixed because it shakes and have been advised by the dealer that it cannot be fixed. At 1000 to 1500 miles I developed a vibration between 60 to 75 mph. I now have 2000 miles on the vehicle. Cannot be fixed. Awaiting possible buy back. Hope you do not become one of the many 99-2004 Silverado owners who have joined "Club Shake".
Old 12-30-2004, 07:23 PM
wyatt21 wyatt21 is offline
I have a 04 2500 4x4 extended cab and have the exact same noise. The noise sounds like a cross between wind and a constant valve clatter. I just took it to the dealer to have it checked out and they said it was normal. I have ridden in a lot of Chevys and it isn't normal. I'm taking it to a different dealer to get a second opinion.
Old 12-31-2004, 03:34 PM
91zxtt 91zxtt is offline
Yes, the bug deflectors cause this. The local shop here used a bead of silicone under the window moulding to make it stop.
Old 12-31-2004, 08:51 PM
camping camping is offline
Is it usually on the top or bottom of the molding?
Old 01-08-2005, 02:07 AM
You would want to run a small bead under the molding. You should be able to slide the tip of the applicator under the moulding. When you're done, you can't even see it.
