Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-28-2004, 05:44 PM
dansneet dansneet is offline
Unhappy I need help ID'ing this hose.
New guy here. I need help figuring out what this hose is/does. I'm thinking it might have something to do with the transmission but I may be way off. It's my father in laws '89 Crown Vic. The hose ruptured as he was driving on the freeway and he saw white smoke coming from the rear.
I've outlined the hose in red. Anyone know?
Thanks in advance.
close up
close up from passenger side
Old 12-28-2004, 07:40 PM
backyard_mech420 backyard_mech420 is offline
That is your heater to manifold coolant hose,with this hose busted the car will be undrivable as you will lose all your coolant within about 5-10mi.Luckily it is the easiest of the coolant hoses to change.It costs about $1.00 a foot at most auto parts stores,it is called 3/4in Heater Hose,You should need about 3ft. of hose and 2 new hose clamps.Just loosen the hoses clamps at each end with a flathead screwdriver,if it dos'nt come off when you give it a good pull,put a vertical slice down each end of the hose and pull the sides back.It should then come off with no problem.Measure the new hose against the old,and cut it to the correct length,route the hose in the same position as the old one,install the hose clamps,push each end of the hose onto the coolant hose connectors and tighten the hose clamps down tight.Hope this helps.
Old 12-28-2004, 09:19 PM
Thumbs up
Thanks a bunch for the info!
Looks like it will be a fairly simple repair.
