Old 12-28-2004, 04:33 PM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
Angry Have you ever had one of those kits !!!!!!
Just wondering who else has had a kit where everything you do seems to go pearshaped? I bought a Fujimi 1985 Porsche 911 cabrio off ebay for a song, it was started but buildable, the body needed a strip and repaint and so did the chasis, no problems here other than I mixed my paints and got crackle, second time got a great finish, other breakages etc along the way, maybe its because its an old kit but the plastic seems brittle, this has been my last cause of mishap. I was painting the sun visors prior to final fitment and the windsreen just split in two, a few expletives later and a count to ten and i'm calm now. Being an old kit i'm not sure if I can get a replacement from Fujimi direct, but I also wont be beaten by a piece of plastic anyone with any suggestions or has anyone got a spare?
Old 12-28-2004, 04:41 PM
Blazing Rice Blazing Rice is offline
I've had kits that I just wanting to burn.
Does that count?
Old 12-28-2004, 05:11 PM
lilbudman's Avatar
lilbudman lilbudman is offline
Send a message via AIM to lilbudman
I'm working on a fujimi RE amemiya r-x7, and the fitment is the worst I've ever ever had to deal with. Yesterday I was ready to just throw it out the window.
Lil'budman
Old 12-28-2004, 06:34 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Have you ever had one of those kits !!!!!!
Yes...yes I have. Every kit I build is that way.
-Mike
Old 12-28-2004, 09:21 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I've had several kits like that - the Revell Integra gives me trouble no matter what. I've started 4 different versions of this same kit and all have ended up in the "screw it" pile.
If you can't get a spare from Fujimi, put some tape over the windsheild and make a pattern. Transfer the pattern to some clear plastic sheet, and cut it out a little oversize. Test fit until your eyes bleed then epoxy it in place... and pray for the best. I've seen this done a lot to improve scale thickness of the glass parts by modelers with much more skill than I - they would even notch the window frame to accept the new windsheild! I'm sure a simple windsheild job is well within your abilities. Good luck!
Old 12-28-2004, 10:26 PM
Jaymes's Avatar
Jaymes Jaymes is offline
my camaro project's going nowhere right now cause I messed up the spoiler 5 times. I almost threw the whole car into the wall at one point, but I'm glad that I held down my temper.
Old 12-29-2004, 12:48 AM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I think they are reissuing one of the '85's...
A bit of cutting to fit a coupe windshield into a cab though. An RS series windshield should fit fine too.
I don't think there is a kit out there that doesn't require some special finess to finish, though most times it's my little changes that add that little extra to push the skill level rating into the stratisphere!
SCCA 7, The lost Z
Old 12-29-2004, 01:45 AM
primera man's Avatar
"P-Man"
Yep.
Most revell kits !!
Worst one i've done would be the ITR as nothing seemed to fit without a battle
View All My Models Here.
Old 12-29-2004, 12:28 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Go to your local hobby shop and get some acetate, used by aircraft guys to make canopies. Glue your original windshield together, sand the seam and make the windshied surface as smooth as possible, heat the sheet over boiling water, and stretch it over the old windshield applying as little force as possible to get the shape. Let it cool, trim off the excess and you should have a workable piece! Looks better if you dip it in Future too!!
My AF Classic Model Car Gallery
Old 12-30-2004, 02:42 AM
Hyperkinetic's Avatar
Hyperkinetic Hyperkinetic is offline
Originally Posted by Verminator
I bought a Fujimi 1985 Porsche 911 cabrio and the windsreen just split in two. Being an old kit i'm not sure if I can get a replacement from Fujimi direct.
I had the same problem with a Fujimi Porsche 911s.
As both Revell Germany and Testors produced exactly the same kit I have contacted them for a replacement part of 'their' kit. Within 3 weeks I received the windows from one of them (don't know which of them sent it).
On the workbench:
Gunze Jaguar XK-E / Tamiya Peugeot 405 Pikes Peak / Fujimi Ferrari 365 GTB
Hyperkinetic Rabbity Thing!!!
Old 01-02-2005, 03:46 PM
Verminator's Avatar
Re: Re: Have you ever had one of those kits !!!!!!
Tried it and got away with it, luckily the porsche windsreen is fairly flat, a point to note though is that epoxy wont stick to clearsheet for overhead projector use, however superglue will and I found it didnt fog up either, but only used the barest amount, I also replaced the front quarter lights while I was at it. Anyway its worked a treat and salvaged a project for me. Thanks to Willimo and you others
Old 01-02-2005, 04:10 PM
Technoman's Avatar
Technoman Technoman is offline
Fujimi Enthusiast Series Porsche Carrera 911 73 Safari rally version. This thing fits together like a series of round pegs in square holes. I put it away for now, I will return to that battle another day.
Old 01-02-2005, 04:18 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
I've had plenty of those.. There's a pile of burnt
cars outside of my garage .
Old 01-03-2005, 09:11 AM
Rtuned's Avatar
Rtuned Rtuned is offline
I got lots of these kind of model too, but with some battle to fight and it will be look pretty killer But what I really think is, that's where the fun come in. To solve all error and problem during the building is very exciting to me.
Old 01-03-2005, 10:33 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
i'm building a replica of a racing skyline a friend runs and its made of bits of all different kits, problem's that its somewhere between the jgtc skyline and the R34 V-spec II road car so sticking new front splitters from a racing on and the spoiler off a kei office S15 aint easy, when you want it to look good.
good luk though, i had the same problem with my evo 5, i finished it perfectly and just as i was about to put the icing on the cake the wind screen/shield split.
Seatbelts Saved My Life
