Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 12-28-2004, 04:16 PM
00civicsir 00civicsir is offline
je pistons, computer programming?
Planning on installing je pistons in my b16a (1.6). Was wondering if anything needs to be done to the computer as for as compression ratio is concerned?
Old 12-30-2004, 01:58 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
Re: je pistons, computer programming?
are you changing the compression ratio or keeping the same compression ratio that you had, if changing are you going higher or lower and how much?
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 01-02-2005, 07:17 PM
do i have to change the compression if so what would be the best com;ratio an what is stock i was thinking about 10;5 or would stock work good with a set of skunk;2 cams i have AEMcold air intake-DCheader-catbackexhaust-Greddymuffler-AEMpully's
