Old 12-28-2004, 04:36 PM
85firebirdtransam 85firebirdtransam is offline
Question Scraping noise?
When im turning left and only left and hitting the gas it sounds like my front passenger tire is rubbing on the well and my car is scraping the ground if anyone can help i will be very thankful.
Old 12-28-2004, 04:42 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Re: Scraping noise?
may be a bent spring or bad shock causing the car to tip to that side making the tire rub and scrape the ground. are you running the factory size tires?
Old 12-30-2004, 11:15 PM
tx_1987_gta tx_1987_gta is offline
I noticed that on my 87 GTA, shortly after rebuilding her, that the larger front sway bar in combination with just a slightly wider front tire than what came on the car made the tire rub the sway bar when turning in a lock to lock situation. I have beed told that a simple thin spacer plate between the hub & the wheel would solve this problem.
Thanks, Joe
Amarillo, Texas
Top of Texas Trans Am Club of Amarillo ( Founder & 2007 President )
http://www.transamclubofamarillo.com/
1987 Trans Am GTA, Hardtop, 350 T.P.I.
1989 Formula 350, T-Top, 350 T.P.I.
1989 Turbo Trans Am #402, T-Top, 3.8 Auto
1991 Trans Am GTA, Hardtop, 350 T.P.I.
1996 Camaro RS, T-Top, 6 Cylinder,
2000 Ram Air Trans Am, T-Top, LS1, Auto
Old 12-31-2004, 06:05 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: Scraping noise?
spring sag or broken springs,tires too tall or wide, or broken rubber bump stops are all possible problem areas.
Your steering and/or suspension is simply worn out more than likely.Shocks will help for awhile,but wear out in 15k miles or so,if your springs are in the condition i think they are(20 yrs old).
A bad steering center link,pitman or idler arm, or tie rod end(*A* frame busings too) can be the reason for rubbing too,as well as a possible safety hazard.
It could be that 20 years of front-wind has warped the plastic inner fender closer to the tire,but if you cant figure out what the problem is,take it somwhere and have it looked at.Make sure a wheel isnt about to fall off or somthin.
