Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 12-28-2004, 03:03 PM
real977 real977 is offline
NEED HELP PLEASE!!!!! how to install a tachometer in a 87 crx si??
what color of the wire do i hook up the tach to? the wire that makes the
pointer move? help please
Old 12-28-2004, 03:47 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: NEED HELP PLEASE!!!!! how to install a tachometer in a 87 crx si??
According to my trusty Haynes manual, you will want to attach it to the blue wire coming off of the ignitor in the distributor.
Old 01-02-2005, 05:30 PM
mormilesthanne1 mormilesthanne1 is offline
i have a 87 civic and i put an aftermarket tach in. there were four wires coming off of the tach; black, red, green,and white. i put teh green through the hole in the firewall and sodered it onto the green on teh ignition coil. if you give me more information i can definatly help you out
Old 01-02-2005, 06:08 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
the negative post on the coil
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 01-02-2005, 06:25 PM
lxndr's Avatar
AF -Advisor
Re: Re: NEED HELP PLEASE!!!!! how to install a tachometer in a 87 crx si??
That will work too and was my first thought. On my old cars that's where I hook up a dwell meter/tachometer. Although my CRX manual says that the signal for the stock tach comes right off of the ignitor. I suppose if you were installing an aftermarket tach, it would probably be easier to hook it up to the coil.
I wonder why anyone would need two tachometers in their car?
Old 01-02-2005, 06:47 PM
cvcc_wagon's Avatar
not every model came with a tach. it was and still is a marketing tool for Honda, the nicer model comes with a tach and the lower ones do not. my car didn't come with a tach but other 83 and earlier models (including the wagon) came with one.
i shold also mention that my dads 2002 5 speed civic didn't come with one either
Old 01-02-2005, 10:57 PM
lxndr's Avatar
AF -Advisor
Every 1G CRX came standard with a tach. The SIs had them simply because they were SIs, DXs had 'em, and HFs had a tach along with a shift light in order to tell the driver when to shift for efficient gas mileage. I'm not trying to put anyone down, I am honestly interested as to why someone would need 2 tachs. I can see that a race car needs to have a tach and shift light within easy eye sight in order for the driver to maintain consistent shifts... but a street car?
Old 01-10-2005, 04:04 AM
ok
well, where is the ignition coil of the crx, because to tell you the truth, i dont where the ignition coil is
Old 01-11-2005, 12:58 AM
cvcc_wagon's Avatar
a cylinder that the wire in the center of your distributor goes to.
