Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-28-2004, 01:26 PM
DEL RODEO DEL RODEO is offline
Rodeo jerks at highway speeds
I have a 2000 rodeo LS (120K) it was running rough, stalling and jerking while driving at highway speeds. Dealer said EGR bad and replaced, also told me to replace crappy plugs I put in with NGK's , I did that. Seems to have helped alittle since I no longer have the stalling when I come to a stop but engine feels like it wants to. Also while driving at highway speeds it seems to buck or jerk forward. Other day when I started it up the check engine light stayed on as well as the reduced power light which I have never seen before, had the pedal almost to the floor and had no power, the next day it was fine. any suggestions?
Old 12-28-2004, 03:14 PM
rodeo02 rodeo02 is offline
You have to use denso spark plugs on the 2000+ 3.2L. That is most likely your problem (LOTS of posts on this). Get them here if you want: http://www.sparkplugs.com/more_info....63261&pid=9619 What codes are you getting? You really need to start by reading the code(s)
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
