Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-28-2004, 12:44 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
check engine light. BCS warning, cyl. # 4 misfire
My check engine light has been on for a while now. It only happened after my valve job @ 115K miles.
Before the v/j, I had installed an MBC & 15 psi, a FIPK, and GReddy type-S. I had these on for 2 months; no check engine light came on.
Right after getting the v/j done, a ton of codes came on...cylinder 4 misfire, BCS warning (which I had disconnected, ofcourse, because of the MBC), etc etc.
The obvious culprit is the valve job. I want to know if any of the mods I have listed in my signature can cause a check engine light to go off, from your experience.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 12-28-2004, 05:03 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: check engine light. BCS warning, cyl. # 4 misfire
to get rid of the BCS light just leave the electrical connector plugged in. once you disconnect the hose from it it doesnt do anything but if its plugged in then it wont throw a code.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-30-2004, 02:32 AM
Shpyder's Avatar
Moderate moderator
so by pluggin the bcs back in with all the hoses, it should be fine?
Old 12-30-2004, 08:16 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
You don't need to re-attach the hoses, just the electrical connector on the BCS. As for the misfire, I don't know if that would be caused by the BCS not being plugged in or not.....I wouldn't think so.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-30-2004, 11:22 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
yeah, just plug the bcs back into the harness and zip tie the bitch to somthing. i used vac caps on the two vac lines becasue i had some laying around. that will fix the wastegate code. i have no idea about the cyilnder #4 misfire.
DSM geek
