Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-28-2004, 12:02 PM
JJ052653 JJ052653 is offline
Anti-freeze smell
I am smelling anit-freeze when car is warming an approaches 150 degrees, then the smell disappears when the engine is obtaing normal engine tempature. can anyone tell me what is going on ?
Old 12-28-2004, 06:19 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Anti-freeze smell
Do you smell the antifreeze inside the car or outside? You may have a leak in the heater core that is causing the smell. Do the windows fog up when you turn on the heater? If not then check to make sure all the hoses clamps are tight and there are no leaks anywhere under the hood. If a clamp is not tight it could leak until the hose expands and then stop causing you to smell the antifreeze.
Old 12-29-2004, 12:00 PM
I can smell the anti-freeze on the in-side when the heater is on and on the outside. when the car warms up, the smell disappears from the inside, but you can smell it from the outside. The smell appears to be coming from the side were the EGR value is located in the engine compartment. The window are not fogging up when I turn the heater on. I did check all the hoses with the exception of the connection to the thermostat, which is near the EGR value. The weather was a little bit warmer this a.m. and I did not notice the smell on the inside or outside. You may be right, some hoses may be expanding after the car is
at operating tempature.
thanks for the suggestions
Old 12-29-2004, 06:28 PM
Pontiac Guy
Check the tightness of the thermostat housing. It may have vibrated loose and is allowing a small amount of antifreeze to leak. Be careful not to overtighten. Hopefully this will cure your problem.
Old 02-21-2005, 11:44 AM
Luke Home's Avatar
Luke Home Luke Home is offline
Re: Re: Anti-freeze smell
If you live where it is cold/very cold outside, I would guess the hose clamps are loose. When the engine warms up it expanse and the hoses seal. I have this problem on my 94 Bonney.
1998 Bonneville SE 156,000+, Miles, Running Good So Far
1999 Camry LXE 105,000 3.0 V6 (1MZ-FE Engine), A541E Trans.
1997 EAGLE TALON ESI 2.0L L4 SFI DOHC 16V (Project Car - 140K)
Old 02-21-2005, 11:55 AM
Skyline316 Skyline316 is offline
Banned
maybe u goit an anti freeze leak?
