Old 12-28-2004, 10:25 AM
Todd1974 Todd1974 is offline
94 LeSabre heater control
I have a 1994 LeSabre and the heater control will not switch out of "Heat" mode. Also, it appears that the rear defroster does not work. Is this just a faulty heater control panel or could there be something else causing this?
Thanks a lot,
Todd
Old 01-11-2005, 08:49 PM
keithchevy keithchevy is offline
Re: 94 LeSabre heater control
i am having the same problem some times heat comes on all bye it self
Old 01-13-2005, 10:55 AM
Sydni Sydni is offline
Ya, I have a 95 lesabre and the component that swithes from heat to air does not work. To replace it would cost a lot so for now I just have it stationed at "heat". It is found behind the glove compartment and is easy to switch over to air, when the need arises.
Old 01-13-2005, 10:57 AM
My rear defrost doesnt work either, apparently it just needs a fuse replaced, but I cant find where the fuse would be!
Old 01-21-2005, 07:53 AM
buicks=oldguycar buicks=oldguycar is offline
Re: Re: 94 LeSabre heater control
I have a 93 Lesabre and there's a fuse panel under the dash on the passenger side [behind the plastic cowling under the dash...stupid place for fuses! ]. You might want to try there...I think they mention it in the owner's manual, but I'm not sure.
You may also have a hairline crack in the supply line to the rear defrost [actually on the window itself, even if there's no crack in your glass...] These are supposed to be easy to repair, but I've never had to do one...
Good luck!
