Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-28-2004, 08:18 AM
solarisdx solarisdx is offline
Rodeo Speakers & Audio
I'm considering redeeming a best buy gift certificate to purchase some new speakers to replace the factory installed ones that my rodeo came with. (1999, 4cyl, 2wd)
Does anyone have any recommendations for the type of speakers that I should be purchasing? I know little about car speakers and would appriciate any purchasing recommendations. I know that my Rodeo takes the 6.5" in the front and 4" in the back.
So far, I have been looking at some Pioneer speakers on the Best Buy website.
6.5" front door speakers
http://www.bestbuy.com/site/olspage....6&type=product
4" rear speakers:
http://www.bestbuy.com/site/olspage....4&type=product
Old 12-28-2004, 08:36 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Rodeo Speakers & Audio
I think just about anything you replace them with will sound better. Also, if you still have the factory head unit I would replace that first.
And.... I think the speakers in front and back are both 6.5" You may want to check out crutchfield.com to make sure on the size.
here are a couple of links to how to install:
http://carstereohelp.com/stereoremov...migo1FSpkR.htm
http://carstereohelp.com/stereoremov...migo1RSpkR.htm
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-28-2004, 11:01 AM
megavolt121 megavolt121 is offline
Basically any speaker you can buy @ BestBuy will work. I had Sony Xplod's in my old car and they sounded fine. I'm running Some JL Audio(pricey) in my Rodeo now. Somehow I recall that you have to use 5.25" speakers and not 6's because they are too deep and will hit the glass. Also if you like to turn your music loud and are afraid of blowing speakers, get the extended warranty. ITs basically a no questions asked, we'll replace it on the spot one.
Old 12-28-2004, 09:41 PM
Letsrodeo's Avatar
Letsrodeo Letsrodeo is offline
The front doors will accept 6.5", but you'll have to modify the mounting plate to get them to fit.
The Pioneer speakers you have selected are coaxial, meaning they have a built in tweeter. Your doors have a tweeter built in.
My
I would recommend you upgrade your 5 1/4" door speaker with a mid/bass woofer (non-coax speaker) and perhaps later upgrade your tweeters. Coaxials for the rear will be fine.
Another thought would be to sink your money into the front door mid/bass and tweeters and leave your rear speakers as is. The rear is usually just for fill. 99% of what you want to listen to is the front channels.
My approach to upgrading a sound system is to consider future mods and expansion. The greatest gain over a stock system will be to add an amplifier. Speakers fail due to too much distortion more often than from to much power. Factory CD players as well as aftermarket players are not big enough to provide sufficient power to drive most speakers. People crank the volume up on low power systems to distorted levels and ruin their speakers. Clean quiet power is the way to go.
Another thought.........
Speaker sensitivity, the higher this value the less power it takes to drive them. Use Watts RMS not peak power when selecting speakers and head units (CD player, radio unit).
Here's some suppliers I've found helpful when looking for audio equipment.
Parts Express
SoundDomain
AudioBahn
Rodeo Audio Installation
Happy listening.
If you want something done right do it yourself two or three times!
1999 Isuzu Rodeo LS 4X4
American Eagle Series 149, 16X8
Toyo Open Country LT265/75R16
Rancho 9000
3" CP Lift, 3" PA Body Lift
Manual Locking Hubs, SuperWinch
Optima Yellow Top Battery
Custom Sound System
Shrockworks Rocksliders
Letsrodeo
Old 12-28-2004, 09:44 PM
Thanks so much for the advice so far.
The speakers in the back are definitely 4". My speakers are not on the sides of the rear cargo space... but are on the roof, just behind the glass hatch. Best buy's website allows you to set preferences to your car's make and model and will only display products that fit your car. 4" in the back, 6.5" on the sides.
Amigo-2k, I have a Pioneer CD player in the dash. Replacing the factory radio and cassette player was done within the same week that I got my car!
I tried to remove the back panel to expose the 4" speakers today but had difficulty doing so. I'm gonna try to find a guide to that like the ones you posted earlier.
Old 12-29-2004, 07:30 AM
Letsrodeo's Avatar
The rear back panel will snap off, but you have to remove the lens cover on the convenience light then remove the exposed screw. Next snap the panel off. A plastic putty knife will help with romoving interior trim pieces like these.
Rancho 9000
Custom Sound System
Letsrodeo
Old 12-29-2004, 10:03 PM
Re: Re: Rodeo Speakers & Audio
THANK YOU!!!
Old 02-04-2005, 09:52 PM
smarquez1 smarquez1 is offline
If you buy the rears from Crutchfield, they throw in the adapter so changing out the rears takes about ten minutes and a philips screwdriver, nothing else . . . Kenwood used to make a 5 and quarter that is shallow enough to fit the front doors--I think Crutchfield can tell you the number and then I found them on eBay--no easy in adapters, but not too hard an install. Be sure to use some washers on the mounting screws to make up for the size difference in the speakers and the mounting plate--it's a small difference, but they'll slide around and maybe fall wihtout 'em. If you figure out how to get at the tweeters in the door without taking the truck halfway apart, let me know . . .
Old 02-05-2005, 12:49 AM
Isuzu Guy
http://www.geocities.com/treading_lightly/audio.html
http://www.geocities.com/treading_li...cbinstall.html
couple of new old links.
-Ryan
Isuzu Moderator
Car Show Tips
