Old 03-06-2002, 04:21 AM
dgdarien dgdarien is offline
Once again.. The Starter Kill
okay so I know there have probably been alot of topics and questions about a starter kill. But alas, I need some help as well.
So I have a 2000 civic EX, And I read all these articles about switches and relays and what not. But all I want to do is install a simple switch to cut off the fuel pump.
I need to know where and which wire should i attach a switch to, and is it safe to install a switch to that wire. Thanks in advanced guys.
Old 03-06-2002, 08:00 AM
Tireburner's Avatar
Tireburner Tireburner is offline
Attaching anything to a fuel pump wire, or any other wire in a vehicle, that upon failure of the attached part, could cause loss of power, thus loss of control of a vehicle, is highly not recommended.
I have done fuel cutoffs, but I make the consumer sign a disclaimer form.
Toggle switches are too easy to find in most cases. A flat switch, a pulse timer relay, an external relay and a diode. Cheap (parts about $20.00) and highly effective.
Why isn't common courtesy more common?
Old 03-07-2002, 01:16 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
It's a good idea but make sure you hide the switch in a REALLY good place. And try thinking of something else to run it to such as the starter instead.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Once Again.....the Ignition Module Puruco Blazer 5 02-11-2006 07:33 AM
