Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-27-2004, 09:49 PM
dolphinsa87 dolphinsa87 is offline
leds in air vents to switch
I want to hook up some led's to my car in the air vents and i know how to mount them etc... and I know that the postitive end is the longer end of the LED but what I want to know is how do I wire it to the switch. I know that I wire to postitive end to the ACC im pretty sure and then I think mabye the negative to the ground but I dont know how to hook it up to the batter. Any help would be appericated. Please let me know what i am doing and also how would I connect them all to one switch?
Old 12-28-2004, 08:28 AM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
Re: leds in air vents to switch
If you hook the pos to ACC then it will come on when you turn your car on. Then you wouldn't need a switch because it would always be on when you car is turned on. Although if you want to run a switch run a wire from the ACC to one end of a switch and then from the other end of the switch to the led pos. And neg does go to ground.
John 3:3
Jesus answered and said to him, "Truly, truly, I say to you, unless one is born again he cannot see the kingdom of God."
Old 12-29-2004, 04:31 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
why do you want to light the inside of your air vents nasty interior? the idea is nice, but the vents are gonna get nasty, and you won't want them lit up...
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 12-30-2004, 06:09 PM
It's not to light up the interrior of it. It's to give the entire vent a nice glow to it, it more or less shines out of the vent, you can't see the inside of the vent. If done right it can look very cool. I like the idea but I haven't decided if I am going to do it yet.
John 3:3
Old 01-06-2005, 11:28 PM
stretch2802 stretch2802 is offline
first: neg goes to body ground not battery ground.
pos. can go two ways. you can either run wire from lights to switch through firewall then pos. batt. if you want control of on\off. or run lights to ignition <on> switch (check fuse box for correct wire) so they are on when car is on ..BUT.. do you really want them on ALWAYS when the car is on? i ran all mine (25 leds) through switch cuz there's no reason for them to be on during tha day.
Old 01-07-2005, 02:36 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
body ground is battery ground
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 01-08-2005, 08:52 PM
swaptrex swaptrex is offline
sounds like a good idea to me, i think the led's would give the interior a nice touch.
Old 01-08-2005, 08:59 PM
Problemsolver Problemsolver is offline
The best way would be to use a test light and find a terminal in the fuse pannel that is hot with the lights on. This way would eliminate the manual switch and they would only be on with the lights.
Old 01-09-2005, 07:52 PM
ground to your body 97civicX not BATTERY . any way if they are illegal to run in your state due to distraction of other drivers(what a cop would say) a toggle switch is better than wiring to light fuse
Old 01-09-2005, 07:54 PM
but if you still want them on when your headlights or parking lights are tured on .
run hot wire through firewall and splice into parking lights hot wire
