I was given a 1976 Granada. I will be performing a 5-lug and front disk brake swap on my 1966 mustang useing the granada parts. This granada also has a 302 and a c4. For the time being I'm going to swap in the 302 and c4 until i finish building the 351. Also I wont have to "shoe-horn" the 302 like I would have to do the 351. Now I am in the process of buying Edelbrock's Performer RPM power package for this 302. I already have a 750cfm Edelbrock Performer carb and the Performer RPM Air-Gap for the 302. I know a 750 seems a little large for a street drivin 302, but I called Edelbrock and they swore by the 750 for this build. It is a manual choke/manual secondaries. I am buying the heads this week and getting the Performer RPM hydro roller cam and retrofit lifters in a couple weeks. I am buying Speed Pro hyper pistons that should put me around 10:1 with the 60cc heads.
Now, my question is about the stock bottom end. I'm looking to get around 400hp here and was wondering if the stock crank and rods from a '76 302 are strong enough to last around 6500 rpms. Thanks for any replies.
1969 Cougar 357w & TKO - 475hp |
Re: 1976 302
Yes it take it, but for how long?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
I don't think you will get 400 horses with the set up you describe but it will still feel impressive. I think the lower end can take 6500 but I wouldn't recommend it a lot. I think your power band will be lower than that anyway. The brake set up will be a good swap too. Good luck, Lovie
Yes the stock crank will take 6500rpm's, the rods can be another story... first I'd want to know what Ford OEM con-rods they use in 74(I'm not sure, will decide if you should do the following), next I'd de-carb em and polish em, then rebuild them wit new ARP hardware. With this they'll be good for your HP level in a non boost motor. Also I would only do this on a motor that has all new bearings.
Now saying that... I think your gonna not need to worry bout 6,500rpm's. I think you'll find that the Performer RPM package is gonna choke out round 6,000rpm. Also what heads are you using? valve sizes? Finally your not gonna run RR with a girdle or shaft-mounted RR's, I think your gonna start to get valve float at 6,500rpm again causing your power to drop off. After you build this motor and slap it on a dyno I think you'll find closer to 6,000rpm is where you will make ya peak HP.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Re: 1976 302
I planned on having the bottem end shot-peened and polished if I used them, as well as re-equiping them with ARP components. Also I was planning on running Edelbrock's Performer RPM heads, 2.02/1.60. I called Edelbrock and the promised me that I would not have valve float at 6500 rpms. I told them I was useing their hydraulic roller camshaft and they said I had nothing to worry about. Not to mock you but, Finally, The heads I have picked out have studs, not shaft mounted. So yes I will be running roller rocker arms.
If I where useing stock heads I would have valve float before 6500 rpms. Probably closer to 5800-6000. Oh, and its a '76, not '74. Thanks for the replies though.
Re: Re: 1976 302
Also any head designed for stud-mounted RR's can use shaft-mounted rockers.
