Old 12-27-2004, 06:05 PM
dandyl dandyl is offline
clutch change?????
my 97 z28 does not like a clutch dump it wont spin and i think its slipping the clutch...could it be a slave cylinder doing this dirty deed or is it strictly clutch related???
Old 12-28-2004, 01:18 AM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
Re: clutch change?????
Could be the clutch disc itself. Recomend getting a stage two performance pak clutch set up if your going to be dropping the clutch for burn outs and crap like that. They last a long long time. 300% longer than a OEM clutch under equal wear. You also may want to check your pilot bearing ( throw out bearing ) make sure your clutch is actually engaging all the way. Under your car , Where the engine and tranny mount together around the bottom side of the bellhousing should be a inspection panel , remove it and look for warped / broken or damaged items , such as peices , shavings , dry spots , a large amount of clutch dust.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 12-29-2004, 09:08 PM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
my 97 z28 had the same problem. the result was the lt1 oil leak had oilsoaked my clutch and it just slipped like crazy
Old 12-29-2004, 09:49 PM
92rs25th's Avatar
That will do it too. The clutch is supposed to remain dry as a bone
1992 RS Camaro 383.
2004 Mazda 6.
1984 Nissan 300 ZX
Old 12-29-2004, 10:06 PM
black84z28 black84z28 is offline
pilot bearing is the small bearing the input shaft slides into...not the same as the throw out bearing..the 93-97 cars have the pressure plate and throw out bearing in one whole unit..
get rid of that stocker and get a mcloed or spec stage 3...have your flywheel turned before the new one goes in too
Old 12-30-2004, 05:03 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
have you noticed a decrease in gas mileage? a slipping clutch will allow higher crusing rpms and drink up more gas. its a bit of a give away.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
