Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-27-2004, 06:12 PM
amberchamber amberchamber is offline
help! is my shaking 2000 maxima dying?
hi, i got my 2000 maxima 4 months ago from the 1st owner, who kindly replaced all six ignition coils for me and since then it ran well till 3 days ago. when i was backing the car in the morning the car shaked a lot! but when i shift the gear to move forward, the shaking disappeared--then when i backed it again, it did not shake at all. but the following morning when i backed it, it shaked still and it has been 3 days in a roll any person has similar problems? can my max live with me for another couple of years?
Old 12-29-2004, 04:52 AM
tts tts is offline
Re: help! is my shaking 2000 maxima dying?
I also had vibration problem with my 2000 Cefiro (which I think it has similar 6 cyl. VQ engine used in Maxima.) The Nissan computer shown an error in ignition system was later checked out by the mechanics that #1 cylinder ignition coil was bad. The ignition coil was replaced and the vibration has "improved", I said improved because there is still some weak vibration occasionally however I suspect that is caused by the worn spark plug that Nissan suggested me to replace. I will replace the worn plug shortly and will let you know if that would eliminate the problem completely.
Old 01-09-2005, 02:21 AM
Re: Re: help! is my shaking 2000 maxima dying?
that will help! thx! does that work better?
anyway, i let the engine go for a while and the shaking has not come back for a while~~
Old 01-09-2005, 04:14 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
"...2000 maxima dying?"
- Yes. Starts from day one. Thats the bad news. However there are a lot of things the owner can do to extend that life. I have one -93 purring better than new, see my web page and apply things applicable (most are identical). Have fun!
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-09-2005, 10:33 AM
tts tts is offline
Re: Re: Re: help! is my shaking 2000 maxima dying?
I changed spark plugs and the engine is definitely running smoother and idling much quietly, and last two tanks of gas seemed to have shown 7-8% improvement in gas mileage. However, the weak vibration still return occasionally at warm start (there is no vibration at cold start !) I have been trying an old practice of step down on gas pedal slowly all the way to the floor (and release) before a warm start, that seem to have prevented the vibration in last two day, I need to do that for couple more day to see if that really works, if so, it could mean there is a failure in warm idle mechanism which I will ask the Nissan mechanics to look into that again.
