| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
soft brakes
ok there is no fluid lost from the master cylinder and the brakes have been bled multiple times and have also been replaced. I'm wondering if it would be the brake booster or anything else, its a 92 civic.
Re: soft brakes
have you replaced the brake pads? i had the same problem were i had to push the brake pedal to the floor to stop sometimes and i thought i didnt have enough fluid. but as soon as i replaced the pads the brake pedal didnt travel as far.
the pads are almost new
Re: soft brakes
i know that replacing the regular brake lines with steel lines will harden the brakes some.
bubbles in the brake lines?
Re: soft brakes
Before I had to slam my brakes all the time due to air bubbles in my lines. My weak master cylinder was creating these bubbles even after I bleeding my brakes several times. Once I replaced the master cylinder it was fine. When the springs or components inside the master cylinder are worn out it creates air bubbles on it's own.
Tsudo N1 Catback Custom 4-2-1 Header Custom Hi-Flow Cat Custom CAI Exedy Organic Fidanza Flywheel NGK Iridium Tokico HP Suspension ADR DV8 Sandblack Rims Nankang NS-1 Rubber |
Re: soft brakes
so i should look into a new master cylinder, which leads to my next question. Im trading some parts for a disk brake conversion on the back so will i need to get a better master cylinder or is it the same in a integra and civic with drums in the back.
Re: soft brakes
well you will need to increase master cylinder to increase the pressure of the fluid to the brakes,
if you dont your pedal will be longer than what you have now when freshly bleeded, and for the rear disc conversion youll need a 40 40 proportioning valve from a integra or a sir (si in the us) a master from any civic or tegs will do, as for the prop valve, any from a 94-01 teg non abs should fit there w |
You can also get a proportioning valve from Wilwood for $45, and it's adjustable. I'm doing front and rear integra brakes on my Civic. And since the car is so old you should replace the brake lines. Steel braided are ideal of course. If yopu are doing the rear disc conversion make sure to get the brake lines for the car you have in the 4-wheel disc trim.
Re: soft brakes
the diaphram in the brake booster might have been punctured...otherwise i would say that you have air in the lines.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
thank for all the help ill probly go with a integra master cylinder
