Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 12-27-2004, 03:51 PM
uniontrooper uniontrooper is offline
fuel filter location? `99 Sable GS
Trying to locate fuel filter for `99 Sable GS...car does not have owner`s manual. Any suggestions? Thanks
Also, does anyone else have excessive fuel consumption issues with the Sable? This is 3.0 V6 engine. Seems to use a lot of fuel...hence, changing out the fuel filter.
Old 12-28-2004, 01:58 AM
KimMG KimMG is offline
AF - Advisor
Re: fuel filter location? `99 Sable GS
How many miles are you getting to the gallon?
Fuel filters don't burn gas. They may cause fuel delivery problems if clogged.
Public libraries have repair manuals available if you are not ready to purchase one.
Follow the fuel lines from the tank to find the filter.
When was the last tune-up? What do the spark plugs look like? Is the air intake clean?
Old 12-28-2004, 10:09 AM
Thank you for your reply. In response to your questions:
I calculated roughly 10 mi./gallon....we drove 40 miles on a full tank...at 40 miles we were under 3/4 tank.
The spark plugs were changed less than 4000 miles ago, they were a bit carboned, but gapped properly. Plug wires are in good condition from plugs to distributor.
I changed the air filter at the same time, the filter showed normal dirt accumulation, nothing clogging the intake...a flashlight and a shop vac picked up nothing.
The vehicle accelerates well, no missing, but changing out the fuel filter won`t hurt. We have had a lot of problems with this car, and from the message board, it seems that Sables don`t have a good history.
I did locate the filter and going to O`Reilly`s shortly to buy a new one.
Thank you again, sir, for your response. Uniontrooper
Old 12-28-2004, 06:33 PM
AF - Advisor
Carboned spark plugs means the car is running rich.
Using the gas guage is not an accurate way to calculate fuel mileage. Fill the tank, set the tripometer to zero, drive, fill the tank again, and divide the number of miles by the number gallons purchased to fill the tank.
Example:
200 miles = 10 gallons
200/10 miles = 10/10 gallons
20 miles = 1 gallon
After changing the fuel filter, try using a fuel injector cleaner (the parts guy should know a good one) and see if this improves things. Slightly clogged fuel injectors will not allow the fuel to properly atomize.
The air intake can develop a black film causing poor fuel economy. Every tune-up I do on my truck, I have to clean the air intake and butterfly. It looks like a black carbon film coating the inside of the air intake. This will improve the fuel economy on my pick-up.
Old 12-29-2004, 06:43 AM
tcguertin tcguertin is offline
Re: Re: fuel filter location? `99 Sable GS
Example:
20 miles = 1 gallon
Think of the fuel use this way. Your car is suppose to get roughly 28 miles per gallon, you say it is getting 10 miles per gallon then where is the other 6.5 tenths of gas going every 28 miles? If it's leaking, you should see it or smell it, if it is not leaking then the car is running very rich so it doesn't perform like it should because it is running rich. In this case their is no in between. Connect a good scanner and check the opertion of the emission and fuel system.
Tom
HardCore Ford
Old 12-31-2004, 09:45 AM
I changed out the spark plugs, replaced fuel filter, ran a half tank of premium gas and injector cleaner thru the engine.....seemed to do the trick. Sables are a bit quirky, I think, because now the heater works properly, also, since doing this. Thanks for all your help, folks. Uniontrooper
Old 02-15-2005, 08:19 PM
kfazzina kfazzina is offline
Passenger side rear door,
