Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 12-27-2004, 02:46 PM
1999PassatVW 1999PassatVW is offline
Clock and trip odometer display
I recently blew a fuse for the trunk light. I replaced the fuse and now the clock starts at 12:00 every time I start the car. The clock will appear to work, displaying the hour and minute 12:00-12:01-12:02 etc. However when I shut the car off, the clock resets back to 12:00 when I turn the car back on. The trip odometer displays 0 when the car is turned on and properly records the miles. It resets to 0 when the car is turned off and turned on again.
Any suggestions for fixing this problem?
Old 12-27-2004, 09:31 PM
boschmann boschmann is offline
Re: Clock and trip odometer display
You may have also lost the memory power fuse.
Old 01-18-2005, 08:29 AM
Your suggestion solved my problem. The fuses were loose, and after I reset them, everything worked. Thanks
J
