Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-27-2004, 01:55 PM
911h20 911h20 is offline
2002 Suburban Keyless Remote
Does someone have the instructions to program the remote(s) for a 2002 Suburban 1/2 ton. Thanks!
Old 01-07-2005, 06:45 PM
Logixman Logixman is offline
Talking Keyless remote programming GM
Hi,
Here is a program I found that works on my 2000 suburban.
1. Get in you car (have all the remotes that you want programmed with you at this time, even if you have one that works already because this procedure will reset that one as well). close the door
2 While holding down the unlock button on the driver side door:
A. put the key in the ignition and turn to the on position then to the off position then again to the on postion then to the off position (don't be too slow when you do this, probably all four motions within 5 seconds). do not remove key from ignition yet.
B. Immediatley release the unlock button. You should hear the lock system cycle within a few seconds. This indicates that you are in program mode. If you don't hear the locks cycle go back to step 2
C.Take your first remote and hold the lock and unlock buttons at the same time for about 15-20 seconds (most instructions say seven seconds) until you hear the locks cycle. Your first remote is now programmed.
D. Repeat step C for all other remotes at this time
3. Once you have programmed all your remotes turn the ignition key to the on position, this exits programming mode.
