Old 12-27-2004, 01:53 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
How to make your own shifter cable stiffeners
This is an inexpensive way to tighten up your shifter, and get better shifts.
You will need :
- 4 skateboard Bearing
- TIG/MIG welder ,or rubber cement, or neither
- some kind of clamp or press
- 1-4 washers
- steel rod the same diameter as the inside ring of the bearing
- plyers
- dremel tool or file
- A 22mm or 7/8" socket
There is 3 ways to do this ,first way is most expensive & best, Second way is the second best way & moderately expensive, third way will work fine & is the least expensive.
1)TIG/MIG:
- take two of the bearings and slide them onto the steel rod, (this helps keep the bearing straight ,and true to each olther, basically keeps the bearings aligned)
- make sure the bearings are up aginst each olther so they can be welded together
- Set up the welder so it is on the lowest heat setting (bearings will cease if it is too hot)
- put a little spot weld on the bearings to hold them together
- two spot welds should hold it (keep the welder on the bearing no longer than 1 1\2 to 2 seconds, bearing will get to hot and cease if the welder stays on there longer)
- grind the welds down so they are flush with the outside of the bearing
Istallation notes:
simply remove the old bearings
and install as pictured below....
2)Rubber Cement:
- Place the two bearings on the steel rod
- glue them together using rubber cement
- make sure to keep the glue all on one rotaitng mass of the bearing , dont want to glue it together so the bearings dont spin.
Installation notes:
Istall as pictured below....
3)Neither
- grind down the outer ring of the bearings so it fits easyly on the inside the shifter cables ring
- this is more of a looser fit ,so if you grind the bearing down to far it will not work right or even fall off
- use washers to elimninate most of play on the bearings
installation notes:
washers need
might need a stronger cotter pin..
INSTALLATION:
Step 1: Gain access to your shifter cable ends at the transmission. This will require removing the intake pipe and anything else that may be in the way.
Step 2: Removing the stock rubber from the cable ends. If you have older cables the stock rubber often will just stick to the pins on the transmission when you try to pull them off. If this happens you may have to cut off the rubber and inner metal sleeve with a cutting wheel. Otherwise take a piece of stiff metal that will fit through the hole on the pin and keep the rubber bushing in place while you pull up on the cable. Take care now to bend the cable by only pulling on the metal end.
Step 3: Giving yourself some room to work with. Take out the locking clips that hold the shifter cables in the transmission bracket. This will allow you to have more room to work with. If you can't get these loose get a large flat blade screwdriver and pry on the edges of these clips to try and work them up and off.
Step 4: Cleaning up the cable ends. The bearings are a VERY tight fit in the shifter cable ends. This is good so they don't fall out or slide around. The only bad thing is that it makes getting the bearings in the cable ends all the harder. If you have the cables out of the car and are using a press or a large vise you don't need to clean up the ends. If you are putting them in on the car then take a dremel and a fine grit sanding drum to the inside of the cable ends. Don't go nuts here as all you want to do is take a very tiny amount of material off. With the dremel on a medium speed and light pressure a few seconds is all you are looking to do.
Step 5: Pressing the bearing kit in half way. This is where you will need a small vise or other clamping tool with flat surfaces to press the bearing in. Putting a light coat of engine oil or other lubricant on will aide getting the bearing in. Make sure to keep the bearing going in straight. Simply clamp down on the bearing and the shifter cable end and start to press the bearing kit in. If you manage to get crooked get a socket that will fit inside the cable end and tap the bearing kit out and start over. If you can't seem to get it started and going in straight take the dremel and sand a tiny tiny tiny bit more.
Step 6: Pressing the bearing in the rest of the way. Once the bearing kit bottoms out on the vise you will need a socket to allow pressing the bearing kit in further. A 22mm or 7/8" socket works well for this. Put the socket over the cable end opening that doesn't have the bearing sticking out. Start to clamp down again. This will allow the bearing kit to be pushed further into the cable end. If it doesn't push through try readjusting the socket as you may have and edge blocking the bearing from coming through. Go in small increments until the bearing kit is pushed through evenly. If you manage to go too far then simply put the socket on the other end and push the bearing kit back slightly.
Step 7: Reassembly. It is adviseable to clean up the transmission pins that the shifter cable ends attach to. You can use the dremel to clean them up or a small piece of sandpaper. Put some axle grease or thick lubricant on these pins to keep them from rusting and to allow easy removal in the future. The bearings may not feel like they will drop down onto the pins but with a good push they will fall into place just make sure you are putting them on straight. Put the cables back into the transmission brakets and put the locking clips back in place. Put on the cotter pins and enjoy!
Now you have stiffer and more precise shifts!
thanks to Machv.com for the installation instructions....
Good luck,
-Jake
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-27-2004, 05:57 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: How to make your own shifter cable stiffeners
Can you feel the difference in shifting?
For Sale 98 Eclipse GS, 5 spd
Old 12-27-2004, 07:50 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Nice writeup. somebody should put this in the FAQ thread
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-27-2004, 07:53 PM
97_3clipse's Avatar
Re: Re: How to make your own shifter cable stiffeners
ya i can , when you shift it goes right into gear , none of that half in half out of gear crap.
Old 12-27-2004, 10:00 PM
kjewer1 kjewer1 is offline
AF - Advisor
Yes, I did the rollerbalde bearing upgrade a couple years back, night and day difference! So cheap too... I still have the stock shift plate bushings and everything else (i.e. symborski kit) and it works well. I did get rid of the rubber cable bracket mounts years ago though, but I don't recall tht makig a huge difference.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
