Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 12-27-2004, 11:30 AM
Jeff O Jeff O is offline
91 Mighty Max No Start Click at ECU
Intermittently, the truck won't start. Doesn't turn over, but I hear a clicking noise from ECU when I turn ignition key. Can get car started by push/jump starting. Doesn't seem to be related to car hot/cold. I replaced ECU about 18 mos ago with a remanufactured unit--problem then was no spark. Does it sound like the ECU is out again with different symptoms?
Old 01-12-2005, 05:39 PM
punxnotdead punxnotdead is offline
I'm having the same problem with my 92 summit,if you find the problem and or solution please let me know.
Thanks
Old 01-27-2005, 11:44 PM
4g63tMmax 4g63tMmax is offline
Did you check your starter?
Old 02-11-2005, 02:12 AM
Spooln Spooln is offline
Re: 91 Mighty Max No Start Click at ECU
Second that for sure, crack it a couple of times from below with a rubber hammer it just might start then replace it if it does.
Old 02-12-2005, 08:05 PM
dinoraver3466 dinoraver3466 is offline
Re: Re: 91 Mighty Max No Start Click at ECU
The starter relay is right next to the ecu... see if that gold box is "clicking"
Old 10-22-2005, 05:28 PM
mikelly7 mikelly7 is offline
Re: Re: Re: 91 Mighty Max No Start Click at ECU
What if the gold box is clicking?
Old 10-23-2005, 10:00 AM
FD5 FD5 is offline
My 92 did the same thing, started a few time by jumping off and always when push started, I had cleaned the terminals on battery, checked all wire connections, still nothing. Turns out it was the starter, 39.95 at autozone for lifetime warranty starter, truck running fine now.
1992 Mighty Max
Independent Amsoil Dealer
Old 12-05-2005, 08:32 PM
My truck need a started also! Thanks
