Old 12-27-2004, 11:54 AM
salem1oliver salem1oliver is offline
Amp install Kit?
Does it really make a difference what gauge amp install kit you use. I am trying to save a little bit of money and found a 10 gauge kit for $25. But would I be better off going with a 8 gauge kit for $38.
Old 12-27-2004, 01:40 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Amp install Kit?
Yes it greatly matters. what amp is it going to how much current draw? And how far will the power wire run? Check out www.weldingsupplies.com It's not pretty but works good. If you need good looking wire then go get some off ebay.
Old 12-27-2004, 02:41 PM
it is for an 820 watt max Power Acoustik amp that I plan to bridge to one channel for a max of 460RMS to run my Adire Audio Shiva Sub. There is a good possiblity that the wire may be seen a little.
Old 12-27-2004, 07:05 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I always go with pretty big wiring and use off brand stuff, it's a LOT cheaper. The last bunch was 4 Ga wire by amp king or whatever, got it from MCM prety cheap.
Old 12-27-2004, 10:15 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
knukoncepts.com makes really nice wire that is priced fairly cheep.
Old 12-28-2004, 02:52 AM
Now if I already have one amp installed in the car with power running from the battery do I need a complete amp install kit or do I only need some RCA cables and speaker wire for my sub.
Old 12-28-2004, 05:42 PM
Audio Guy
depends on whether that wire can handle the current for both amps
