1996 - 626 Cornos- Not starting
In -8 degree cel. I drove my car home and parked in garage. It was 2 minutes later, I tried to start it again and it would not start. Its been almost 20 hours, car is inside the garage but not starting.
It gives the clicking sound when I try to start it. Battery seems to fine. I use to get the battery charge light, when all the lights are on and fan is running. Got the alternator checked, everything is fine. Mechanic said it could be some sensor problem that light battery charge ligh come on but chraging is fine. PLEASE PLEASE HELP before I spend lot of money. |
Re: 1996 - 626 Cornos- Not starting
First, check air cleaner, should be clean, pull and check plugs, should not be black, and check gap. After putting plugs back in get a $1.50 can of strating fluid, put a short shot down intake..A SHORT shot then try to start.. if it tries to run or runs for a couple of seconds, its a fuel problem and you need a new fuel filter, or a fuel pump. Hope this helps....Later Mark
