Old 12-27-2004, 08:52 AM
gonzo694 gonzo694 is offline
Send a message via Yahoo to gonzo694
Thumbs up Oil Psi When Running And Idleing?????
Can Anyone Tell Me Whats The Psi When The Truck Is Running And What It Should Be When Idleing???..my Truck Starts Off At 42psi When Started And Then Drops To 20psi When Idling After Its Been Driven For A Little While Til The Engine Warms Up But Recently Its Dropped To Aarond 18at Idle.....i Must First Say It Is Only 10 Degrees Will The Temperture Affect The Psi After Running Or Can I Be Looking At A New Oil Pump????? Thanks For The Help .....happy Holidays....
Old 12-27-2004, 03:01 PM
nineball481's Avatar
nineball481 nineball481 is offline
Re: Oil Psi When Running And Idleing?????
Mine is at 40psi-idle and 60-70psi-running. I have a 2000 2wd 1500
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 12-27-2004, 03:50 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
What year make and model is your vehicle?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-27-2004, 10:32 PM
i have a 1995 silverado 4x4 ...i spoke to my mechanic and he threw in a 10w-40 after he changed my intake manifold gasket....does this seem right to anyone ????I dont want to second guess him but i dont want to screw up my motor or have a big expense later on ....if i need a new oil pump let me know please..and if you think hes ripping me off let me know cause i dont want to trust him and spend alot of cash if hes jerking me around and waiting for it to go so he has the business of replacing it and charging me big money????im sure u all know were im coming from just wish i had the know how id do it myself....thanks guys
Old 12-28-2004, 06:40 PM
catback23 catback23 is offline
Not sure what prompted him to change your IM gasket but heavier oil is a hail mary fix for low oil pressure. Mechanics typically do it on high mileage engines that are worn and showing low pressures, it's not a bad way to fix it but it's not an actual fix either because all it does is mask the problem whether the problem be a worn oil pump or engine.
As far as your pressures I'm not sure what the specs call for but I wouldn't be too worried about the 18 psi at idle with a cold engine in cold weather. If the 10w40 helped your pressures quite a bit then you may need an engine overhaul or oil pump.
Old 12-28-2004, 06:53 PM
rabt's Avatar
rabt rabt is offline
10 PSI for every 1000 RPM's is plenty enough oil pressure starting at 15 PSI being the lowest
Old 12-28-2004, 11:10 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
I have a 92 K1500 (same engine as yours, 5.7L TBI), and these trucks don't run as high of oil pressure as the newer trucks (99-up).
Once my truck comes up to temp., it idles (in gear) at about 15-20 psi, and runs on 35-40 psi. As long as the pressure jumps (literally) back to 30-40 psi as soon as you touch the gas (and I mean just barely touch it too, not rev it hard) then you're fine.
However, if it takes it a while to build the pressure, then you need bearings, or really, just an overhaul.
Edit: Aslo, even if you do have a problem, it more then likely wouldn't be the oil pump, it would be the bearings. However, if you did get an overhaul, its a given to change the pump (and the pistons, and the rings, and all of the bearings).
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
