Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 12-26-2004, 11:55 PM
dyt dyt is offline
Removing Dash when installing deck in 05 Accent
Do I really have to remove the whole dash to remove the factory deck on an 05 Accent. Normal DIN install or what? If so, whats the easiest way? This is probably a stupid question...
Old 12-28-2004, 03:50 PM
rally_wrc rally_wrc is offline
Re: Removing Dash when installing deck in 05 Accent
Only the panel around your radio and heater knobs needs to be remved. Open you cup holder and remove the screws inside the pull the bottom out working your way up the sides to the top. it is held on by clips, you will also have to unclip some other knobs and buttons along the way. Hope this helps, email me if you run into trouble.
Old 12-28-2004, 08:41 PM
dyt dyt is offline
rally...thanks for your help. After I get that far, it seems the whole air conditioning unit is attached to the panel. Am I missing the clips or something because the whole unit for the heater and vent knobs is attached by screws to that panel facing toward the engine and I've tried and tried to get a screwdriver in and it's not going to happen! I have to shove my hand in w/ the screwdriver up under the dash by the gas pedal through all the wiring just to get to those stupid screws! Help, I'm stuck and I have to do another install and I'm not trying to go through that again.
Old 04-13-2006, 12:15 PM
Matt.Halfyard Matt.Halfyard is offline
u dont need to pull the air conditioning unit out u should have enough room to be able to sauder wires or whateer and all of that with it left on if you take it off it will be more work for you i got my new deck in with it left in the clips are on the sides of the panel around the radio and stuff try not to loose them they like 20 bucks i think for 4 little clips HAHA
