Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-26-2004, 09:15 PM
Emittim3 Emittim3 is offline
Creaking noise at passenger window - Eclipse spyder convertible top
I'm having an issue with creaking noise coming from the upper area of the window frame of the Eclipse Spyder convertible top, model year 2004. It occurs with bumps, when the top moves most. During cold weather it worsens, and as well at high speeds (70+) it will start creaking. If you put pressure against the window, the creaking will stop. As well, a very slight lowering of the window will also remove the creaking noise issue. The driver's side does not do this, just the passenger side.
Has anyone had issues with this creaking sound in their Spyder soft tops? If so - what are some suggested remedies?
I've thought of treating the weather stripping with something, in hopes that would remove the creaking noise. But I'm not sure what would be a good thing to treat the weather stripping with - I hear that armor-all is a terrible thing to use.
Suggestion?
Thanks!
Old 12-26-2004, 09:18 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Creaking noise at passenger window - Eclipse spyder convertible top
armor all will be bad for the weather stripping. you might qwant to check in the 2000+ forums to see if anybody there has had this problem
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-26-2004, 09:42 PM
Thanks - posted in that forum as well.
Yeah - armor all is crap from what I hear. Never use the stuff. I used to use a product called 'Tannery'. I remember it being good stuff - but not sure how it works on modern day plastics and polymers. All I do today is just use a mild soap and water moistened sponge on my cars and Jeeps. But, I've tried that already on the weatherstripping. Cleaning it doesn't remove the creaking issue.
Thanks for the response!
Old 12-26-2004, 10:35 PM
george536's Avatar
george536 george536 is offline
if its a 2004? shouldnt it have warranty for stuff like that? take it to mitsu and tell it started doing that out of no where
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
