Old 12-26-2004, 06:20 PM
bigbob bigbob is offline
convertable stiffening
hey fellas, if i put a 6/8 pt roll cage in my 95 gt convert. will it be as stiff or stiffer than a coupe? im hoping itll be much stiffer, thanks.
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 12-26-2004, 07:10 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: convertable stiffening
much stiffer than an unstiffened coupe. however if you did the same to a coupe he'd outshine you a ton. make sure you add aftermarket sway bars, weld-on full-length subframe connectors, and aftermarket strut and shock tower braces. then it'll be about as good as it'll get.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 12-26-2004, 08:34 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
A mod that costs considerable money but If I had a vert I would seriously consider would be Griggs racing thru the floor sub-frame connectors. The major cost is in the fact that for these subframes you need to pull the interior,seats, carpet, deading material, cut the floors cause the connectors go inside of the subframes but the chassis stiffing they create even over standard sub-frames is worth it.
This mod increases chassis stiffness by 200% and would keep the sweet look of your vert with the top down which is why I would consider them in that situation.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
