Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-26-2004, 05:13 PM
95cutty 95cutty is offline
Send a message via AIM to 95cutty
vibrating and dying
i have a 95 cutlass supreme with a 3.1 in it. we recently did a lot of work starting with new head gaskets, got the heads milled, new intake gaskets and spark plugs plus some sensors. the problem is that it wants to die when i am sitting at a dead stop. it will start back up and run as long as it is getting gas. i also had new injectors put in it. i dont know if this could be caused by a bad ignition coil or plug wires. it also has a vibration at around 50 mph and up. the vibration i noticed is also there after it dies and i restart it, the vibration is at lower speeds. could this be a misfire from a bad coil or wire. any help is appreciated. also i check the site regularly so if u post something i may have another question for you so if u could also check this thread i would appreciate it. thanks for any help or advice anyone can give.
Old 12-27-2004, 11:01 AM
kippy kippy is offline
Maybe the crackshaft sensor. I saw similar problems in a Ciera with a 3300 although there was no viberation at high speeds. The engine just stalled whenever it wanted to. sometimes it would start right away and sometimes it won't.
Old 04-01-2005, 08:52 PM
g2driver g2driver is offline
Re: vibrating and dying
Have you checked the timing?
Old 04-03-2005, 11:49 AM
Ryan066 Ryan066 is offline
if it ildes down and tries to stall when you come to a stop it is prolly a bad distance/speed sensor.
