Old 12-26-2004, 04:58 PM
jmolle1 jmolle1 is offline
1994 Grand Am - sputters
My son's 1994 Grand Am recently started sputtering. This would happen when he first started the car - and most recently while out on the highway going 65+ mph. We replaced the spark plugs - and now it won't start. Besides replacing the spark plug caps, is there anything else we can do to get this car running again?
Could the sputtering be caused by a bad ignition coil?
Any help would be appreciated!
Old 12-26-2004, 05:36 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: 1994 Grand Am - sputters
could actually be a bad alternator - also sounds like the cat converter could potentially be plugged. I dunno about the coil though - I guess you could try it if it wasn't the cat or alternator.
Old 12-26-2004, 06:00 PM
swalt's Avatar
swalt swalt is offline
If it is cranking but wont fire, check for spark on each wire. Pull off each wire at a time put one of the old plugs in it and touch it to the block while someone cranks over the engine and check for spark. (Use a pair of long needle nose pliers when you do this and hold the rubber cap not the plug. You will get a good jolt if you hold the plug and your pliers are not rubber coated on the handle) If the wires are original on the car, I suspect you have a bad wire and would replace them anyways given the age. If you find you don't have spark at two of the plugs, then that coil is bad.
Old 12-26-2004, 06:28 PM
autozonesucks2000 autozonesucks2000 is offline
we got thos silly lil plug wires 44yys also is the control module hooked up,that was something i missed when I changed theh coil pack
Old 12-29-2004, 08:52 PM
Car is running great...ended up the coil pack needed replaced. Thanks for your replies.
J
