Go Back   Automotive Forums Car Chat > Saab > 9000
Old 12-26-2004, 04:15 PM
johan j johan j is offline
Unhappy intermittent stalling
can anyone advise?
engine cuts out suddenly - usually the second I drive over a bump on the road. otherwise runs fine, no misfires or anything.
when it cuts out, lights, heater etc stay working. RPM's fall gradually in line with speed as I coast to a stop. it will only 'bump start' if the key is 1st turned to 'off' then back to 'on' or it will restart immediately with the key as long as its switched off 1st. no difference if hot or cold, but most frequent when driving 50mph plus.
Replaced DI cassette, crank sensor, fuel filter & relay before realising it was bumps in the road causing the problem.
I think its got to be a bad connection somewhere but don't know which one(s) could cause just the engine to cut whilst not affecting anything else.
Old 05-30-2005, 12:34 AM
phatpat80 phatpat80 is offline
Re: intermittent stalling
look for damaged ignition wires ir a bad connector to the directignition unit if so applyed best i can do from here
Old 07-02-2005, 02:41 AM
vk3kbr vk3kbr is offline
Had a simmilar problem, it turned out to be the fuel pree-pump. For me it would be worse in hot weather and / or if the tank was low. Othewise might be the primary pump on the way out to, if you have over 200'000 kilometers I'd be suspicios of the pree-pump.
Old 08-19-2005, 12:51 PM
shortlid shortlid is offline
How about the ignition switch, there are wear points on these cars! If you fiddle with the key in the ignition does it do it?
Old 08-22-2005, 02:20 PM
mbunakeith mbunakeith is offline
i have seen ignition switches cause similar symptoms. might be worth it to check fuel pressure too.
