This morning I was watching HORSEPOWER TV (on Spike) and they were talking about a TT system more the chevy 350 small block, I didnt catch the name of the company that makes this and I am trying to find out because after I see my current car I might purchase a camaro.....I a know about the single turbo system Squires makes but I really want to find some info on this TT system. If anyone knows anything please share....Thnx ahead of time
Re: TT kit for chevy 350 small block
Banks power , The godfather of Turbos.
I love rice so much , I eat it daily. Yum yum Civic. 1992 RS Camaro 383. 2004 Mazda 6. 2003 Subaru Legacy GT Limited. 1984 Nissan 300 ZX 1993 Mazda MX-3 ( Newest addition to my collection. ) http://photobucket.com/albums/y187/ohjiro |
The kit offers 600 bolt on Hp and tuneable to 1100 HP.
yep that name rung a bell, you wouldnt happen to know a their webpage would you?
Yeah I was watching that too, but if you decide to buy just the turbos and not the engine your in for a shit load of work.
I dont want to get a whole engine because I cant even start to imagine how much it will cost...I dont know about the labor cause I done turbo swaps on cars and installed turbos on some others so I think I should be able to handle it cause of what people tell me about the system.
The whole engine runs about 13K and is tuned for 1128 HP at the crank.
13k isn't to bad for that setup
man i was told about 2 days ago you couldn't get that kind of power out of any small block chevy. just go to cars in general and then- comparasion, there pretty much telling me the 4.6 dohc ford is better than chevys LT'S AND Ls series!!
Some guy managed to pull like 3000 HP out of a 400 small block , it was on trucks. when they had Banks , Godfather of turbo talking about it. I know you can pull some serious power out of a small block V8 but I didn't realize that much was possible. SO the next time some one says you can't get jack froma small block , slap them.
hey man i'v actually got a 79 chev 1/2 with a small block chevy twin turbo. runs 12 sec in the 1/4 mile. its very easy to do. i am pretty much the only guy that anyone has seen doo it by the sounds of it. i'v been having so much fun with it i figured y not share with you what i did. its basically a stock 350 i found 2 slightly used trubos from older 6.5 L gm deisel engines from there i mounted them on a flange from the inner fender well one on each side then made a box with 2 inlet ports out of aluminum that bolted on the carb. then just run tubing to the turbo from the carb. for the exhaust i had an older set of headman headers which are basically mount backwards and upside down modified them slightly and welded on a flange then bolts to the turbo. then run exhaust pipe down out of the turbo into ur mufflers. then use the oil outlet for ur oil pressure sending unit t the line one to each turbo and have a line that returns oil back to the oil pan. then i just have a cone type air filter on each turbo. i have had it built and it works amazing the other thing u don't wanna forget is dump valves to limit the amount of boost i'm running 6 lbs from each turbo is nice tame truck to drive on the streets and it still pulls hard and its only a minor adjustment if u want more boost. my engine has 85 000 kms on it and it still runs and performs as well as the day i got it running well good luck and hopefully u get it all figured out
![]() Hey man.. you brought back a VERY old thread.. please try to see the last time someone posted in it beofre posting on the thread.. and if you have something to say about it.. just start a new thread!
Re: Re: TT kit for chevy 350 small block
If yall want answers about turbo sbc's or any turbo setup check out www.lateral-g.net Banks has a section of their own. Excellent site.
Ray In Bama 78Z 355 roller on the GAS. |
