Old 12-26-2004, 01:12 PM
crazy_quick crazy_quick is offline
Timing help
I just wanted to know how the car would run if it skipped a few teeth, because it did that on mine and it didnt even want to move. Just wanna know if any of you guys experienced this?
Suggestions?
Old 12-26-2004, 02:20 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Well depending on how off the timing is it could be anywhere from a few pings and knocks, backfiring, to not running or starting at all I would imagine.
Old 12-26-2004, 05:51 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ya, or your intake and exhaust vavles could interfere, get bent, or even hit the piston, in which case you'd have some fun head-work to do.
always go to worst-case scenario when timing is messed up. a few pings and knocks? ya right, we all wish that's what would happen. the 6G72 engine is an interference engine, in which case the timing is CRITICAL so that the valves won't interfere with each other.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-26-2004, 10:32 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Timing help
Not all 6G72's are interference. My SOHC could snap a timing belt and be back on the road in a few hours. I have heard of people just skipping a tooth or two and the car still runs but runs like shit. If it jumped more than a few then whatever you do, DO NOT RUN IT. You could end up saving a lot of money that way.
Old 12-26-2004, 11:33 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Timing help
The most I have heard of a DOHC engine being off is 6 teeth with no damamge. I think it was the exhaust side.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-28-2004, 11:24 AM
Re: Timing help
Well it was only off by 3 teeth and it didnt hit the piston, heh my brothers dsm hit the piston.
