Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-26-2004, 12:05 AM
IownaDodge IownaDodge is offline
Send a message via AIM to IownaDodge
I am in serious need of help
i own a 1989 dodge dakotathe 4 cylinder engine with a holley carburator. I was driving down the road one day and 1st and 2nd gear went out but before that when i would shift into 4th gear i would lose speed what should i do about that just get a new transmission cuz 1t and 2nd gear wont lock they are just super loose and also when i try to start the truck it just clicks what could the problem be is it the battery or starter? the alternator is brand new i dont know too much about cars so the most in depth detail would be greatly appreciated thank you ahead of time
Old 12-29-2004, 02:28 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: I am in serious need of help
So you got it going once, and this was the same day you were driving it down the road and 1st and 2nd gear went out, and then when you shut it off it wouldn't start again? I'm confused. If it just clicks then how do you even drive it? Do you push start it all the time or what?
My Mopars
Old 01-02-2005, 01:51 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
sounds like a battery problem if it just clicks. as far as the 1st and 2nd not working, you could have faulty sycronizers inside the tranny thus giving you the sloppy feel as it gets into gear.
Old 01-04-2005, 11:38 PM
ya it was the same day and when i actually try shifting into 1st or 2nd it wont go its as if its in neutral i wasnt sure about the battery but that was my idea but i wanna figure out whats wrong with the tranny before i do anything
Old 01-05-2005, 12:54 AM
your 1-2 sycronizer has worn itself out. The chance that the actual gears are sheared is very rare. You can either go to a tranny shop and have them rebuild it or go to a junkyard and find one; if they have that particular one.
Old 01-05-2005, 05:01 AM
how much would it cost for either of those freak sorry im not good with cars i jsut wanna do it cheap til i get a newer car cuz im poor now as it is would the junkyard be cheaper or getting anew one
Old 01-05-2005, 03:10 PM
A junkyard tranny, if you can find one, usually can run around $250 to $600.
