Old 12-25-2004, 07:33 PM
BARtruth BARtruth is offline
Send a message via Yahoo to BARtruth
Angry Not starting
My daughter has a 99 Tracer (same as Escort), when it's at operating temp and turned off, it often will not start when it's tried. The key turns but nothing happens, like it's in drive or reverse. After several attempts it will usually start. Is this likely the neutral switch and if so, where is it located?
Old 12-27-2004, 11:46 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Not starting
I'd bring it to autozone and have the charging /electrical system checked.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 12-28-2004, 06:37 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Re: Not starting
It doesn't have a safety neutral switch. It has what is called transmission range sensor. The transmission has 2 major wiring harnesses coming out of it. The sensors are inside your transmission. Oftentimes these wiring connectors get corroded and have a bad contact. If you can locate 2 wiring assemblys coming out of the transmission trace them to the connectors. Unplugging them and plugging them back in will often correct your problem.
