Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-25-2004, 12:50 AM
Beamer17 Beamer17 is offline
Send a message via AIM to Beamer17 Send a message via MSN to Beamer17
Starting
I have a 93 ford explorer. I just got it from my sister and the starter was replaced a few months ago. It was starting great then all of a sudden did not work one day. so i wiggled the battery terminals and it started. worked fine for two days. wouldn;t start again so i tried wiggling the cables and it did not work. I was stranded in a parking lot so i had to jump the silinoid mounted on the fender with a screw driver. so i figured i had a bad silinoid. i replaced it fired up nice and quick. but the egine was running louder then normal. then it quited down to normal i heard a pop sound not loud like abackfire just a meak pop. and then it went back to loud again so i shut it off. popped the hood and one of the studs on the silinoid had broke. so i removed it and put the old silinoid back in for now so i could get it out of the garage.and nothing happens just a click like usual. so i tried jumping the silinoid again and all i got was clicks. im lost on this.
Old 12-26-2004, 04:39 PM
mfayant mfayant is offline
Maybe you might to replace your battery.
m f
Old 12-29-2004, 01:51 AM
Re: Starting
I tried that still have the problem. there is a slim chance i hooked the silinoid up wrong but when i had ther new one hooked up it started if i had hooked it up wrong it would not of started at all would it?
Old 01-02-2005, 04:37 PM
Re: Starting
n/m i fixed it i had gotton two fualty silinoids in a row and the popping noise was my starter blowing up cause the bad silinoid did not disengage it.
