Old 12-24-2004, 09:56 PM
mikep1117 mikep1117 is offline
Send a message via AIM to mikep1117
rims keep rusting
i have a 91 eclipse and i just got new tires put on and i put on brake pads and rotors and now the back right tire keeps rusting whenever i drive it anyone know whats wrong
Old 12-24-2004, 10:00 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: rims keep rusting
What is rusting? The tire itself? The rim? The rotor?
For Sale 98 Eclipse GS, 5 spd
Old 12-24-2004, 10:46 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
I think u mean the rotors r rusting right? after i got new brakes and rotors(back only) they rust the first week cause i dont garage it.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 12-25-2004, 11:12 AM
theres rust all over the spokes of the rim and the rotors look fine
Old 12-25-2004, 11:57 AM
ashah000's Avatar
Looks like its time for some new rims
Old 12-25-2004, 08:34 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
are you sure its rust and not brake dust?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-26-2004, 06:27 PM
it looks like rust its like dark orange and black
Old 12-26-2004, 07:16 PM
that sounds like brake dust does it wipe off?
-1stGenRocks-
Old 12-26-2004, 09:12 PM
the full spoke will be covered and if i take a brush i can get half of it off then the other half is black and wont come off is there any way to get it off or stop it from coming again
Old 12-26-2004, 09:24 PM
it sounds like you did something wrong when you did your brakes. its hard to diagnose stuff over the internet but doublecheck your brakes back there to make sure they arent dragging which would cause more dust obviously
-1stGenRocks-
Old 12-26-2004, 10:53 PM
macder macder is offline
Send a message via MSN to macder
Did you buy the value brake pads by any chance? Cause if so, those do create allot of brake dust as they are made out of cheaper material. It's allways a good idea to buy the more expensive brake pads especially if you have aftermarket rims.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 12-28-2004, 11:52 AM
ya it was the brake pads i took them off and put on ceramic ones is there any way to get the old brake dust off the rims
Old 12-28-2004, 03:19 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Maybe try washing them! Probably will have to scrub...
