Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 12-24-2004, 07:00 PM
CivicRacerB16 CivicRacerB16 is offline
zex nitrous kit
I have a b16a in my civic coupe, and I was planning on getting a nitrous kit. But I'm kinda of afraid of what it will do if I miss shift. I was wondering if the zex kit had something that wouldn't let that happen. thanks for ur help
Old 12-24-2004, 07:01 PM
oh and I was also looking into their cams and was wondering if they were any good cuz I really haven't heard to much about them.
Old 12-25-2004, 08:30 PM
1gspot's Avatar
1gspot 1gspot is offline
Send a message via AIM to 1gspot
Re: zex nitrous kit
uhhmmmmm yes and no, the zex kit has a WOT switch and usually when u shift u lift ur foot off WOT so there for it wont spray when ur shifting, unless u got ur foot mashed throughout ur shift, in which case dont miss
Old 12-26-2004, 03:34 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: zex nitrous kit
I have accidentally missed a shift and hit limiter while spraying with my zex kit I immediately took her home checked her out and everything was ok. I geuss I got off the gas just quick enough.
Just be extra careful when your shifting if you have that much of a fear.
Im not sure on their B series cam's but I know the single cam crowd generally likes their SOHC cams. Do some searching on google and other sites even honda-tech.com and you should find some good info on the zex cams.
2002 Acura TL Type S
1991 Honda Crx Si
Old 12-26-2004, 07:47 PM
I do not shift while holding dow the throttle cuz I know its hard on the tranny just afraid of messing something up if I miss a gear and it hits the rev limit. I have been trying to looking into their cams and some people say they r good and their prices r very cheap. But, I have heard that they were shit from Richochet on another thread. I know he has been around here for a while so I know that he knows what he is talking about. So, I was just trying to get a little more info but I will still keep looking around. Thanks for ur help
Old 12-26-2004, 09:55 PM
Prelude707 Prelude707 is offline
Send a message via AIM to Prelude707
First off, make sure you get a wet kit. Some people say that dry is fine and your stock fuel system will take care of enriching the mixture. But why risk anything? Let the nitrous system take care of it.
As to your concern about misshifting. Spraying nitrous against the rev limiter is bad news. Your ecu will cut fuel but you'll continue to spray nitrous. This will lead to a lean condition and should give you a series of hard detentions at a very high rpm. There are several options open to correct this.
You could get a MSD ignition/Hondata with rev limiter. This will allow you to set an rpm in which you'll stop producing spark. Set it the same or 100 rpms before your stock rev limiter.
Or you could get a nitrous control unit. I believe NX makes one. This'll allow you to set what rpms you want the system to engage and disengage. So set the system to disengage at the limiter and you don't have to worry. This will also allow you to change activation point depending on what gear your in. So you can set the system to activate at 5000 rpms in 1st so you'll have time to gain traction.
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
Old 12-26-2004, 11:02 PM
well I was thinking about getting the dry kit, I already have a aem fule filter. Not sure how much more it flows than stock. But I was also going to buy the zex inline fuel pump as well just for safety sake. Cuz I have the b16 in a 94 coupe with the stock ex fuel pump and I'm not to sure if it will be able to supply the fuel for the nitrous
