Old 12-24-2004, 05:41 PM
gotboost2ggst's Avatar
gotboost2ggst gotboost2ggst is offline
EVO316g Question
I have these mod on my car Apexi N1 exh Greddy type-s bov Injen intake and greddy turbo timer I want to know when I get my evo316g installed with the 2g kit would my injen intake fit and would my boost be 10 to 12psi cause I have no boost gauge or a boost controller yet?
Old 12-24-2004, 06:27 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: EVO316g Question
does your turbo have an internal w/g?
why would your intake affect your boost level?
Old 12-24-2004, 06:34 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
The intake should fit. Boost would be somewhere around 9psi without a boost controller.
Old 12-24-2004, 06:54 PM
So your telling me the factory setting for a 2g eclipse turbo is 9psi? people tell me 10psi to 12psi?
Old 12-24-2004, 08:32 PM
JoeWagon's Avatar
Banned
There is no setting. The internal wastegate on the turbo you buy will set your boost. It's somewhere like 9-12psi, who cares exactly because you'll have a boost controller.
Old 12-24-2004, 10:06 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
he says he doesnt have a booast guage or boost controller. Definately get a boost guage first then put on the 16g
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-25-2004, 09:02 AM
kjewer1 kjewer1 is offline
AF - Advisor
I would use the stock boost controller with it, usually ends up around 13-14 psi. But I Wouldnt even run a 14b without an aftermarket guage. If the T25 runs away from you it is unlikely to do any major damage. Not true with a larger turbo.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-25-2004, 05:34 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ya just use the stock BCS. should be ok, but seriously get a gauge, even a really cheap one will work for now to be sure you don't blow up from creep or anything.
