Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 12-24-2004, 02:27 PM
JimJim216 JimJim216 is offline
Send a message via MSN to JimJim216
Short shifter
I just got a short shifter for my 98 audi and need to remove the center consule, does anyone have any suggestions for removel or ways to put the shifter in without removeing the consule
Old 12-24-2004, 03:17 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: Short shifter
install write-up
SOLD!
Old 12-24-2004, 07:56 PM
Thanks but thats not going to work, my car is a 98 so it doesnt have that nice little shifter assembly panel that just pops out, to open up the space I need to know how to take out the whole center consule
Old 12-24-2004, 08:37 PM
marked001's Avatar
Moderadur
Re: Short shifter
ok..gotcha.. i cut and pasted this from another post..
Rear part of console is easy.
First remove the cover on the ebrake. do a search on that cuz its hard to explain.
Remove the rear ashtray, there's 3 bolts there. Only remove the 2 bolts in there that bolt the console to the floor. Don't remove the center bolt.
Then you have to move your front seats all the way back cuz there is a screw on each side of the console (just in front of the ebrake handle) where it joins the shifter area of the console. When the seats are moved back you'll see a small plastic clip/cover just like the foot panel ones with some screws under them. Also need to pop out the cupholder and remove a bolt there (same as the rear bolts) which holds the console to the floor.
The foront console is easy once you remove the radio.
Remove Radio. Undo bolts that secure the front dash trim. Find a bolt on the drivers side footwell (pretty far back) that is also behind a small plastic cover and remove that one.
SOLD!
