Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 12-24-2004, 12:09 PM
snowmobilekid400 snowmobilekid400 is offline
Exhaust Help
95 Tacoma 2.7 had the check engine light on and came up with catalyst efficiency low bank 1. The o2 sensors were reading the same. I found that the gasket before the Cat was leaking. I replaced the gasket and cleared the code. It was fine for about 50 miles and then the light came on again. I can hear the gasket leaking again. First thought was the cat was pluged but it was replaced before i bought it a few months ago. If the muffler was pluged from pieces of the old cat i figured the gasket aftrer the cat would blow. Any ideas of what would cause it? I might take the cat off this week to see if it may be pluged for some reason.
Old 12-24-2004, 03:26 PM
i just took the cat off and its rattling alittle bit. I can still see through it but what would cause a new cat to rattle when its only a few months old
Old 12-25-2004, 02:10 AM
superjoe83 superjoe83 is offline
Send a message via AIM to superjoe83
Re: Exhaust Help
sounds like the cat is defective, is the engine running fine? sometimes if you overheat a cat, they will do that
If it aint broke, fix it anyway
