Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 12-24-2004, 07:52 AM
ejr1203 ejr1203 is offline
No Heat
My 86 Fiero does not produce any heat. Any ideas??
Old 12-24-2004, 12:23 PM
thebigunderscoree thebigunderscoree is offline
Re: No Heat
replace your thermostat
Old 12-27-2004, 10:35 AM
Old Lar's Avatar
Old Lar Old Lar is offline
Re: No Heat
It could be a bad thermostat, plugged heater core, or the servo isn't opening the flap that lets air into the heater core.
Also check to see if someone by passed the heater core. Two coolent lines going into the right side of the front "fire" wall (heater core inlet and outlet). Some in warmer climates , when the heater core starts leaking, just remove the lines from the heater core and connect the two lines into a loop.
While you are at it, check the condition of the antifreeze: 50/50 mix.
Old 12-27-2004, 06:01 PM
fierangero's Avatar
fierangero fierangero is offline
Send a message via AIM to fierangero Send a message via MSN to fierangero Send a message via Yahoo to fierangero
Re: No Heat
my temp guage never gets past the bottom limit, but the heater works..?
